setting. There is a range in the spec. Your goal is to rotate the TPS unit until the sensor voltage is within 0.4-0.5V, and there is continuity across the TPS switch. Ideally the TPS switch should cut off at about 900-950rpms. If you can't get both within spec at the same time you'll probably have to buy a new TPS.
